3.0.4 Firmware for MMU3
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
Summary
  • Information for the MK4, MK3.9, CORE One and CORE One L owners
  • Information for the MK3S+ owners
  • List of pull requests
This is the stable release of firmware version 3.0.4 for the MMU3 unit.
This is an updated release containing optimized workflow between the MMU3 unit and the Original Prusa CORE One and CORE One L.
Please note, that this 3.0.4 release must be paired with a specific firmware version for the printer:
Original Prusa CORE One and CORE One L - Firmware 6.5.3-beta or newer.
This firmware release 3.0.4 is not compatible with the MK3S+ MMU3 setup.
  • CI: fix ci-build doesnt have write permission by @gudnimg in #340
  • tests: fix -Wparentheses warning in Github CI by @gudnimg in #339
  • Upgrade ninja from 1.10.2 to 1.12.1 by @gudnimg in #324
  • optimisation: set enum types explictly to uint8_t by @gudnimg in #328
  • optimisation: compare uint16_t against uint16_t in FinishHomingAndPlanMoveToParkPos by @gudnimg in #335
  • registers: remove obsolete comment by @gudnimg in #341
  • idler: reduce duplicate code by @gudnimg in #342
  • Update actions to v4 as some older are deprecated by @3d-gussner in #349
  • registers: support writing axis acceleration value by @gudnimg in #337
  • General USB fixes ported from the new mmu bootloader by @leptun in #323
  • main: reduce duplicate code by @gudnimg in #346
  • 🚧 PFW-1480 Process the Mode command by @gudnimg in #303
  • Force workflows to Ubuntu 22.04 by @3d-gussner in #354
  • Optimise GPIO read/write by moving bitwise shift to compile time by @gudnimg in #355
  • pulley: HomeBack state is never used by @gudnimg in #345
  • Optimize MMU behaviour by @DRracer in #353
Release notes
https://github.com/prusa3d/Prusa-Firmware-MMU/releases/tag/v3.0.4
Posted : 10/03/2026 9:40 am
LarGriff
(@largriff)
A download link would be nice.  It’s not on Prusa Support site yet.
This post was modified 12 hours ago by LarGriff
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Posted : 11/03/2026 2:13 pm
miroslav.h4
(@miroslav-h4)
RE: 3.0.4 Firmware for MMU3
You can find the link to download the FW at the bottom of the page. (MMU3_FW3.0.4+936.hex) Right-click on it and select "Save link as". And then put it on your computer wherever you want.
Posted : 11/03/2026 4:39 pm
Jan Kratochvíl
(@jan-kratochvil)
Member Admin
No download from Support page, because it is for stable releases only. And because 3.0.4 works only with 6.5.3 and newer and there is no stable version yet, the support page has to wait until the Stable release.
Posted : 11/03/2026 4:44 pm
