Uninstall MMU3 from MK4 - how to?
GreenBayRoad
(@greenbayroad)
I’ve installed the MMU3 on my MK4 but have determined that it is too unstable for my needs.  It’s cool but just not worth the time inputs for what I print currently.
I’d like to uninstall it and return the MK4 to stock.
Any instructions?  Do I just reverse the install step by step?
Thank you.
Veröffentlicht : 21/10/2024 3:09 pm
Volker
(@volker)
RE: Uninstall MMU3 from MK4 - how to?
Just disable the MMU in the settings of the printer - that's it. You can manually feed the nextruder as before.
But I'm really wondering about your problems. My MMU ist working without any problems (beside TPU which works sometimes and sometimes not)
Veröffentlicht : 22/10/2024 4:56 am
iftibashir
(@iftibashir)
Remove it physically from the printer.
You will need to reinstall the filament sensor in the extruder assembly as the sensor in the MMU3 has been removed.
You will then need to enter the printer settings and uncheck the MMU3 option.
Veröffentlicht : 03/11/2024 8:22 pm
Anthony Capote
(@anthony-capote)
Were you able to uninstall it successfully? I'm getting MMU3 overcharge issues pretty often and the FINDA sensor doesn't work all the time.
Did you have to change sensors and the nozzle?
Veröffentlicht : 12/11/2024 9:30 pm
