Software and settings confustion
Libor
(@libor-2)
Hello,
unfortunately, I have issues bringing my MMU3 kit to life. I think there are some discrepancies between the guide and the current situation, giving me - a newbie - hard times. I think all the issues are probably small.
1. I had issue with turning the MMU3 on in the printer's menu, getting a confusing message during a test, that filament is inserted and that I have to manually remove it (sure there was none). After some thinking and investigating, I found I was too careful with tightening SuperFINDA, it slid all the way to the ball, thus giving the false reading. I fixed that and I *think* I successfully restarted the test and somewhat passed. I'm not sure, because I know I got few times very confusing message telling me to insert filament into the extruder, which did not seem right at this stage.
2. Next, the manual says to update "Drivers & Apps", but the link doesn't lead to desired download page (just MMU3 overview).
- Link "visit MMU3 page" is not direct: https://help.prusa3d.com/product/mmu3
- Link "version 2.7.3 or newer" leads to Prusa Slicer github page: https://github.com/prusa3d/PrusaSlicer/releases
So I clicked "Firmware & Downloads", but there's no "Drivers & Apps" there... It seems the web site is redesigned and stuff renamed. I tried to browse whole download section, including the main, I tried to google it from outside, but nothing leads to such package. So I don't know if this is *obsolete instruction*, or I'm missing this step (and thus have problem with 4).
3. Next, I've downloaded the latest "Firmware 6.2.6 (3.0.3) MK4S, MK4, MK3.9S, MK3.9" and extracted the content. I put the bbf file to the USB stick, where I deleted the exactly same named file, that came with the printer just few days ago. As expected, printer ignores it, because it's the exactly same firmware version, as the on already flashed yesterday.
I don't suspect there's anything wrong here, but let me know if the firmware under the MMU3 section supposed to be somehow different.
4. Next, I fired up the Prusa Slicer (details bellow) and as per instructions went to Configuration --> Flash printer's firmware, selected the hex file and clicked Load button. Unfortunately, it doesn't connect to the device. I rewrote the screenshot accidentally, but it just says something it couldn't communicate with the printer. At this point I was very tired and demotivated, so I haven't even collected `dmesg` or `lsusb` or other system messages and logs.
I *think* it's because of missing driver as per point 2, but I'm not sure.
So I think "9. Software Download" may have not been done correctly. I do have a Prusa Slicer installed yesterday, including the MK4S/MMU3 profile. I'm currently stuck at "15. MMU3 Firmware flashing (part 2)".
What's obvious to the developer or experienced user is very fuzzy to a new user like me. So I would appreciate clarification on the above pain points.
Best regards,
Libor
PrusaSlicer
Version: 2.9.4
Build: PrusaSlicer-2.9.4+flathub.org
Operating System: Unix
System Architecture: 64 bit
System Version: Linux 6.4.0-150600.23.73-default x86_64
Total RAM size [MB]: 33,464MB
OpenGL installation
GL version: 4.6.0 (4.6.0 NVIDIA 580.105.08)
Profile: Core
Vendor: NVIDIA Corporation
Renderer: Quadro T2000/PCIe/SSE2
GLSL version: 4.60.0
Textures compression: Enabled
Mutisampling: Enabled (4 samples)
Installed extensions:
GL_AMD_multi_draw_indirect
GL_AMD_seamless_cubemap_per_texture
GL_AMD_vertex_shader_layer
GL_AMD_vertex_shader_viewport_index
GL_ARB_ES2_compatibility
GL_ARB_ES3_1_compatibility
GL_ARB_ES3_2_compatibility
GL_ARB_ES3_compatibility
GL_ARB_arrays_of_arrays
GL_ARB_base_instance
GL_ARB_bindless_texture
GL_ARB_blend_func_extended
GL_ARB_buffer_storage
GL_ARB_cl_event
GL_ARB_clear_buffer_object
GL_ARB_clear_texture
GL_ARB_clip_control
GL_ARB_color_buffer_float
GL_ARB_compressed_texture_pixel_storage
GL_ARB_compute_shader
GL_ARB_compute_variable_group_size
GL_ARB_conditional_render_inverted
GL_ARB_conservative_depth
GL_ARB_copy_buffer
GL_ARB_copy_image
GL_ARB_cull_distance
GL_ARB_debug_output
GL_ARB_depth_buffer_float
GL_ARB_depth_clamp
GL_ARB_depth_texture
GL_ARB_derivative_control
GL_ARB_direct_state_access
GL_ARB_draw_buffers
GL_ARB_draw_buffers_blend
GL_ARB_draw_elements_base_vertex
GL_ARB_draw_indirect
GL_ARB_draw_instanced
GL_ARB_enhanced_layouts
GL_ARB_explicit_attrib_location
GL_ARB_explicit_uniform_location
GL_ARB_fragment_coord_conventions
GL_ARB_fragment_layer_viewport
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_fragment_shader_interlock
GL_ARB_framebuffer_no_attachments
GL_ARB_framebuffer_object
GL_ARB_framebuffer_sRGB
GL_ARB_geometry_shader4
GL_ARB_get_program_binary
GL_ARB_get_texture_sub_image
GL_ARB_gl_spirv
GL_ARB_gpu_shader5
GL_ARB_gpu_shader_fp64
GL_ARB_gpu_shader_int64
GL_ARB_half_float_pixel
GL_ARB_half_float_vertex
GL_ARB_imaging
GL_ARB_indirect_parameters
GL_ARB_instanced_arrays
GL_ARB_internalformat_query
GL_ARB_internalformat_query2
GL_ARB_invalidate_subdata
GL_ARB_map_buffer_alignment
GL_ARB_map_buffer_range
GL_ARB_multi_bind
GL_ARB_multi_draw_indirect
GL_ARB_multisample
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_occlusion_query2
GL_ARB_parallel_shader_compile
GL_ARB_pipeline_statistics_query
GL_ARB_pixel_buffer_object
GL_ARB_point_parameters
GL_ARB_point_sprite
GL_ARB_polygon_offset_clamp
GL_ARB_post_depth_coverage
GL_ARB_program_interface_query
GL_ARB_provoking_vertex
GL_ARB_query_buffer_object
GL_ARB_robust_buffer_access_behavior
GL_ARB_robustness
GL_ARB_sample_locations
GL_ARB_sample_shading
GL_ARB_sampler_objects
GL_ARB_seamless_cube_map
GL_ARB_seamless_cubemap_per_texture
GL_ARB_separate_shader_objects
GL_ARB_shader_atomic_counter_ops
GL_ARB_shader_atomic_counters
GL_ARB_shader_ballot
GL_ARB_shader_bit_encoding
GL_ARB_shader_clock
GL_ARB_shader_draw_parameters
GL_ARB_shader_group_vote
GL_ARB_shader_image_load_store
GL_ARB_shader_image_size
GL_ARB_shader_objects
GL_ARB_shader_precision
GL_ARB_shader_storage_buffer_object
GL_ARB_shader_subroutine
GL_ARB_shader_texture_image_samples
GL_ARB_shader_texture_lod
GL_ARB_shader_viewport_layer_array
GL_ARB_shading_language_100
GL_ARB_shading_language_420pack
GL_ARB_shading_language_include
GL_ARB_shading_language_packing
GL_ARB_shadow
GL_ARB_sparse_buffer
GL_ARB_sparse_texture
GL_ARB_sparse_texture2
GL_ARB_sparse_texture_clamp
GL_ARB_spirv_extensions
GL_ARB_stencil_texturing
GL_ARB_sync
GL_ARB_tessellation_shader
GL_ARB_texture_barrier
GL_ARB_texture_border_clamp
GL_ARB_texture_buffer_object
GL_ARB_texture_buffer_object_rgb32
GL_ARB_texture_buffer_range
GL_ARB_texture_compression
GL_ARB_texture_compression_bptc
GL_ARB_texture_compression_rgtc
GL_ARB_texture_cube_map
GL_ARB_texture_cube_map_array
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_filter_anisotropic
GL_ARB_texture_filter_minmax
GL_ARB_texture_float
GL_ARB_texture_gather
GL_ARB_texture_mirror_clamp_to_edge
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_multisample
GL_ARB_texture_non_power_of_two
GL_ARB_texture_query_levels
GL_ARB_texture_query_lod
GL_ARB_texture_rectangle
GL_ARB_texture_rg
GL_ARB_texture_rgb10_a2ui
GL_ARB_texture_stencil8
GL_ARB_texture_storage
GL_ARB_texture_storage_multisample
GL_ARB_texture_swizzle
GL_ARB_texture_view
GL_ARB_timer_query
GL_ARB_transform_feedback2
GL_ARB_transform_feedback3
GL_ARB_transform_feedback_instanced
GL_ARB_transform_feedback_overflow_query
GL_ARB_transpose_matrix
GL_ARB_uniform_buffer_object
GL_ARB_vertex_array_bgra
GL_ARB_vertex_array_object
GL_ARB_vertex_attrib_64bit
GL_ARB_vertex_attrib_binding
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_vertex_type_10f_11f_11f_rev
GL_ARB_vertex_type_2_10_10_10_rev
GL_ARB_viewport_array
GL_ARB_window_pos
GL_ATI_draw_buffers
GL_ATI_texture_float
GL_ATI_texture_mirror_once
GL_EXTX_framebuffer_mixed_formats
GL_EXT_Cg_shader
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_bindable_uniform
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_compiled_vertex_array
GL_EXT_depth_bounds_test
GL_EXT_direct_state_access
GL_EXT_draw_buffers2
GL_EXT_draw_instanced
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_multisample
GL_EXT_framebuffer_multisample_blit_scaled
GL_EXT_framebuffer_object
GL_EXT_framebuffer_sRGB
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_gpu_shader4
GL_EXT_import_sync_object
GL_EXT_memory_object
GL_EXT_memory_object_fd
GL_EXT_multi_draw_arrays
GL_EXT_multiview_tessellation_geometry_shader
GL_EXT_multiview_texture_multisample
GL_EXT_multiview_timer_query
GL_EXT_packed_depth_stencil
GL_EXT_packed_float
GL_EXT_packed_pixels
GL_EXT_pixel_buffer_object
GL_EXT_point_parameters
GL_EXT_polygon_offset_clamp
GL_EXT_post_depth_coverage
GL_EXT_provoking_vertex
GL_EXT_raster_multisample
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_semaphore
GL_EXT_semaphore_fd
GL_EXT_separate_shader_objects
GL_EXT_separate_specular_color
GL_EXT_shader_image_load_formatted
GL_EXT_shader_image_load_store
GL_EXT_shader_integer_mix
GL_EXT_shadow_funcs
GL_EXT_sparse_texture2
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture3D
GL_EXT_texture_array
GL_EXT_texture_buffer_object
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_latc
GL_EXT_texture_compression_rgtc
GL_EXT_texture_compression_s3tc
GL_EXT_texture_cube_map
GL_EXT_texture_edge_clamp
GL_EXT_texture_env_add
GL_EXT_texture_env_combine
GL_EXT_texture_env_dot3
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_filter_minmax
GL_EXT_texture_integer
GL_EXT_texture_lod
GL_EXT_texture_lod_bias
GL_EXT_texture_mirror_clamp
GL_EXT_texture_object
GL_EXT_texture_sRGB
GL_EXT_texture_sRGB_R8
GL_EXT_texture_sRGB_decode
GL_EXT_texture_shadow_lod
GL_EXT_texture_shared_exponent
GL_EXT_texture_storage
GL_EXT_texture_swizzle
GL_EXT_timer_query
GL_EXT_transform_feedback2
GL_EXT_vertex_array
GL_EXT_vertex_array_bgra
GL_EXT_vertex_attrib_64bit
GL_EXT_window_rectangles
GL_EXT_x11_sync_object
GL_IBM_rasterpos_clip
GL_IBM_texture_mirrored_repeat
GL_KHR_blend_equation_advanced
GL_KHR_blend_equation_advanced_coherent
GL_KHR_context_flush_control
GL_KHR_debug
GL_KHR_no_error
GL_KHR_parallel_shader_compile
GL_KHR_robust_buffer_access_behavior
GL_KHR_robustness
GL_KHR_shader_subgroup
GL_KTX_buffer_region
GL_NVX_blend_equation_advanced_multi_draw_buffers
GL_NVX_conditional_render
GL_NVX_gpu_memory_info
GL_NVX_nvenc_interop
GL_NVX_progress_fence
GL_NV_ES1_1_compatibility
GL_NV_ES3_1_compatibility
GL_NV_alpha_to_coverage_dither_control
GL_NV_bindless_multi_draw_indirect
GL_NV_bindless_multi_draw_indirect_count
GL_NV_bindless_texture
GL_NV_blend_equation_advanced
GL_NV_blend_equation_advanced_coherent
GL_NV_blend_minmax_factor
GL_NV_blend_square
GL_NV_clip_space_w_scaling
GL_NV_command_list
GL_NV_compute_program5
GL_NV_compute_shader_derivatives
GL_NV_conditional_render
GL_NV_conservative_raster
GL_NV_conservative_raster_dilate
GL_NV_conservative_raster_pre_snap
GL_NV_conservative_raster_pre_snap_triangles
GL_NV_conservative_raster_underestimation
GL_NV_copy_depth_to_color
GL_NV_copy_image
GL_NV_deep_texture3D
GL_NV_depth_buffer_float
GL_NV_depth_clamp
GL_NV_draw_texture
GL_NV_draw_vulkan_image
GL_NV_explicit_multisample
GL_NV_feature_query
GL_NV_fence
GL_NV_fill_rectangle
GL_NV_float_buffer
GL_NV_fog_distance
GL_NV_fragment_coverage_to_color
GL_NV_fragment_program
GL_NV_fragment_program2
GL_NV_fragment_program_option
GL_NV_fragment_shader_barycentric
GL_NV_fragment_shader_interlock
GL_NV_framebuffer_mixed_samples
GL_NV_framebuffer_multisample_coverage
GL_NV_geometry_shader4
GL_NV_geometry_shader_passthrough
GL_NV_gpu_multicast
GL_NV_gpu_program4
GL_NV_gpu_program4_1
GL_NV_gpu_program5
GL_NV_gpu_program5_mem_extended
GL_NV_gpu_program_fp64
GL_NV_gpu_program_multiview
GL_NV_gpu_shader5
GL_NV_half_float
GL_NV_internalformat_sample_query
GL_NV_light_max_exponent
GL_NV_memory_attachment
GL_NV_memory_object_sparse
GL_NV_mesh_shader
GL_NV_multisample_coverage
GL_NV_multisample_filter_hint
GL_NV_occlusion_query
GL_NV_packed_depth_stencil
GL_NV_parameter_buffer_object
GL_NV_parameter_buffer_object2
GL_NV_path_rendering
GL_NV_path_rendering_shared_edge
GL_NV_pixel_data_range
GL_NV_point_sprite
GL_NV_primitive_restart
GL_NV_query_resource
GL_NV_query_resource_tag
GL_NV_register_combiners
GL_NV_register_combiners2
GL_NV_representative_fragment_test
GL_NV_robustness_video_memory_purge
GL_NV_sample_locations
GL_NV_sample_mask_override_coverage
GL_NV_scissor_exclusive
GL_NV_shader_atomic_counters
GL_NV_shader_atomic_float
GL_NV_shader_atomic_float64
GL_NV_shader_atomic_fp16_vector
GL_NV_shader_atomic_int64
GL_NV_shader_buffer_load
GL_NV_shader_storage_buffer_object
GL_NV_shader_subgroup_partitioned
GL_NV_shader_texture_footprint
GL_NV_shader_thread_group
GL_NV_shader_thread_shuffle
GL_NV_shading_rate_image
GL_NV_stereo_view_rendering
GL_NV_texgen_reflection
GL_NV_texture_barrier
GL_NV_texture_compression_vtc
GL_NV_texture_env_combine4
GL_NV_texture_multisample
GL_NV_texture_rectangle
GL_NV_texture_rectangle_compressed
GL_NV_texture_shader
GL_NV_texture_shader2
GL_NV_texture_shader3
GL_NV_timeline_semaphore
GL_NV_transform_feedback
GL_NV_transform_feedback2
GL_NV_uniform_buffer_std430_layout
GL_NV_uniform_buffer_unified_memory
GL_NV_vdpau_interop
GL_NV_vdpau_interop2
GL_NV_vertex_array_range
GL_NV_vertex_array_range2
GL_NV_vertex_attrib_integer_64bit
GL_NV_vertex_buffer_unified_memory
GL_NV_vertex_program
GL_NV_vertex_program1_1
GL_NV_vertex_program2
GL_NV_vertex_program2_option
GL_NV_vertex_program3
GL_NV_viewport_array2
GL_NV_viewport_swizzle
GL_OVR_multiview
GL_OVR_multiview2
GL_S3_s3tc
GL_SGIS_generate_mipmap
GL_SGIS_texture_lod
GL_SGIX_depth_texture
GL_SGIX_shadow
GL_SUN_slice_accum
Opublikowany : 17/11/2025 8:53 pm
Libor
(@libor-2)
RE: Software and settings confustion
I've just realized the cable I used may be from my old headphones, which would be power carrying only cable. I'll try later another cable, one which should be guaranteed to be data-carrying. Unfortunately, it's little bit challenging topic, with those obsolete USB-micro cables.
Opublikowany : 18/11/2025 10:29 am
Libor
(@libor-2)
Indeed, USB cable was the problem. A fifth cable worked (and I later discovered there's one included in MMU package, which AFAIK is not mentioned in the docs).
The next problem was Access Denied message during the flashing attempt. I've added my user into a relevant group and it went further but again ended up with the Access Denied message. This time I wasn't able to do anything about it, because it seems to be a problem inherited from the silly Flatpak architecture (another reason why to avoid it). So I gave up and as an emergency workaround used my Windows work laptop to flash the MMU3 unit. It now works fine.
Opublikowany : 19/11/2025 9:29 am
