Purge Volumes
flyerdp
(@flyerdp)
Purge Volumes
What are folks using for Purge Volumes?  I assumed the defaults would be sufficient at 70 per extruder but no good.  I went up to 100 and still had some subtle bleed with black or orange back to white.
Postato : 23/08/2023 8:29 pm
K7ZPJ
(@k7zpj)
You need to be using around 300 to stop all of previous color from bleeding into the white color.
Of course the brand and type of filament will effect the purge volume settings.
You can expect to have larger purge blocks when you print with white.
I use a small 2 color  rectangle model to test the purge volumes so I don't have us as much filament to test the purge volumes.
Postato : 23/08/2023 11:03 pm
MysticGringo
(@mysticgringo)
RE: Purge Volumes
You can also adjust purge volumes for individual colors. There's a button next to the infill area on the slicer (not in settings, on the plater screen) that says "Purge Volumes". Here you can adjust how much you purge for individual colors. This way when switching to black from orange, you don't need to purge as much, but when switching to white, you can purge more.
Postato : 24/08/2023 1:51 pm
Loic R
(@loic-r)
Utenti
RE: Purge Volumes
I had same problem with tower purge. Purge volumes is 30 everywhere
I would like to "purge" in objects of my choice but mmu with 1 extruder causes this bug.
is anybody knows how to force one objet before another in the same layer ?
(sorry for my english)
Postato : 02/04/2026 5:05 pm
