Order of Upgrading MK3S+ to MK4 and MMU2S to MMU3
Ken
 Ken
(@ken-11)
Hi all,
I just ordered the upgrades for both units as mentioned in the title.  I had never built my MMU2S or done anything to the MK3S+ to upgrade it for the unit.  So my quesiton is where do I start with these new upgrades.  Will there be a problem following the directions for the MMU2S > MMU3 if the first unit still sits in the box?  Do I upgrade the MK3S+ > MK4 first?  Are there steps that these directions won't show as it's expecting that the MMU2S has already been added to the MK3S+?
I hope you all understand what I am asking.
This topic was modified 2 years temu 2 times by Ken
Opublikowany : 26/06/2024 11:38 pm
RE: Order of Upgrading MK3S+ to MK4 and MMU2S to MMU3
First thing you do with the MMU2 is take it apart to rebuild as MMU3.
Build Mk4 first, print the MMU3 parts assemble MMU3, modify MMU4 Filament sensor, idler and idler catch
 add MMU3, load firmware and set up buffer.... then you should be good to go!
Opublikowany : 26/06/2024 11:54 pm
1 ludzie polubili
Roy
 Roy
(@roy-3)
See the upgrade notes I posted here
https://forum.prusa3d.com/forum/original-prusa-i3-mmu3-assembly-and-first-prints-troubleshooting/upgrading-mk3s-mmu2s-to-mk4-mmu3/#post-712809
My upgraded machine works well.
Opublikowany : 28/06/2024 5:40 pm
1 ludzie polubili
