MMU3 / "Multiple Consecutive Filament Loading Errors"
David Holland
(@david-holland)
I've got the above message popping up on the screen, despite the print completing successfully.
I understand what it is and all, but I've never noticed anything like it occurring.
So, my question is, does the serial log spit something relevant out when it occurs?  And/Or is there a way to reset the counter involved?
I've got octoprint, and am not above performing serial logging for the former.
Thanks,
David
Best Answer by LarGriff:
On the printer, under settings > hardware > printhead > nextruder maintenance, you can reset the error counter.
Postato : 01/01/2026 9:57 pm
LarGriff
(@largriff)
RE: MMU3 / "Multiple Consecutive Filament Loading Errors"
2022 - Creality Ender 3 V2
2024 - Prusa MK4S/MMU3
2026 - Bambu P2S/AMS2Pro
Postato : 03/01/2026 3:53 pm
David Holland
(@david-holland)
Thank you!
I did find it appears the counter appears to be visible via "M707 A0x04" (and settable with a similar command) but that seemed mighty janky... (Also appears I've collected 311 of the things) :-O
I may turn on octoprint's serial logging, and send it to a syslog instance so I can filter out non-movement/non-temperature events and see if it logs anything interesting.
If I go that far, I'll probably put that M707 command on a tool change and/or end of print gcode bit.
Thanks again,
David
Postato : 03/01/2026 4:12 pm
1 persone hanno apprezzato
