MK4 w/MMU3 printing ABS
Ben
 Ben
(@ben-26)
Hi all,
First post here and new to Prusa. I have my printer working, printed a few items using the stock head then added the MMU3 and made all the necessary changes to the print head. Material loads fine, MMU3 is working mechanically as I see the head move and I can get the different materials get loaded. However, now I want to print things using ABS in different colors. This is exactly the reason I bought the MMU head... but I don't see ABS in the list. I've read in a post that there shouldn't be any issues, but aren't then how can I print using ABS if it's not available as an option when slicing?
Any guidance is appreciated.
Thanks,
Ben
Postato : 16/09/2024 5:53 pm
Ben
 Ben
(@ben-26)
RE: MK4 w/MMU3 printing ABS
Hi again,
Got in contact with Prusa support and the reason ABS cannot be selected when the MMU3 is enabled is that they haven't tested multi-colored prints with ABS and that's why ABS is not available to select.
Ben
Postato : 18/09/2024 2:17 pm
vhubbard
(@vhubbard)
Will testing be done for ASA, ABS, PC, PCCF for the MMU3?  If so when will it be finished?
Postato : 18/09/2024 3:50 pm
Ben
 Ben
(@ben-26)
No idea. You should contact them and ask. I'm new to Prusa and just got my stuff working last week.
Postato : 18/09/2024 4:04 pm
vhubbard
(@vhubbard)
Sorry,  just pointing out it may be a while for the other filaments.   I have seen no promises related to other filaments for the MMU3.
Postato : 19/09/2024 3:47 pm
Ben
 Ben
(@ben-26)
Ah. Gotcha.
Postato : 20/09/2024 11:52 am
