Mixing colors
n3wtron
(@n3wtron)
Utenti
Mixing colors
This is my first print after the assembly, and should be a 2 colors sheep (white and black), but during the print the white  filament was mixed with the black one (during wiping), so I printed in 3 different colors with just 2 filaments :D.
Which settings should I change to fix this kind of issue?
Did I assemble something wrong?
Thank you
Best Answer by ironfan72:
You need to adjust the purge volumes, this can be done with the button on the right-hand side of Prusaslicer to the right of the infill option (use custom project specific settings). There's also a "Purge Volume Mulitiplier" option under Filament-Advanced. I've set this multiplier to 100% and then adjust the custom specific settings until you are happy (maybe try 200 for black to white).
Postato : 05/08/2024 9:32 am
ironfan72
(@ironfan72)
RE: Mixing colors
Postato : 15/08/2024 9:30 pm
1 persone hanno apprezzato
