Issues with assembly of mmu3 selector guide bars
dave van etten
(@dave-van-etten)
So I'm assembling the mmu3 from scratch and I'm putting in the guide shafts for the selector slide and the slide works freely till I insert the lower bar and it starts to jam up on either end of travel  how can this be best resolved?
Opublikowany : 04/10/2023 5:29 pm
dave van etten
(@dave-van-etten)
RE: Issues with assembly of mmu3 selector guide bars
The selector slides fine until the lower bar is fully inserted into the final hole then it starts to bind up
Opublikowany : 04/10/2023 5:38 pm
JMH714
(@jmh714-2)
Are you trying to do the Step 15-16?
Is the shaft fully inserted - like all the way in as picture showed (third picture in Step 15)?
Opublikowany : 06/10/2023 5:58 pm
dave van etten
(@dave-van-etten)
yes but i gave up on that for the moment cause it just looks like, under power it seems to move fine. myt idea of moving freely is a bit freer( like sliding with no force). It goes from left to right and tightens up a bit on the far ends of travel but not badly just more force needed to move it.
Opublikowany : 06/10/2023 9:02 pm
Hello
(@hello)
Posted by: @dave-van-etten
It can be a bit tight I found because it's not on bearings it's on brass tubes
Opublikowany : 06/10/2023 10:02 pm
