Copper sleeves slide out
chking
(@chking)
The copper sleeves in the selector just slide out of the selector on the rods.  How do I keep the sleeves from sliding out?
Postato : 28/11/2023 4:37 am
my brass sleeves have always been tight in the selector, maybe try scoring the inside of the sleeve hole with a screwdriver, to raise a burr. would make the fit, tighter.
or perhaps using a soldering iron, to raise small blemishes,,,
or   strip a length of stranded wire and insert a couple of strands to cause an interference fit.
or reprint the selector, with a higher flow rate!
Postato : 28/11/2023 8:52 am
chking
(@chking)
RE: Copper sleeves slide out
I ended up using super glue to hold the sleeves in.
Postato : 20/12/2023 12:37 am
