Can't flash the mmu3
Ryan
 Ryan
(@ryan-14)
Membre
I bought the MMU3 kit with the Mk4s kit. Didn't really have any trouble assembling them and printed several prints with great success on the mk4s before deciding to tackle the MMU. As mentioned, it went together fine. My problem was when I got to step 10 on the MMU assembly instructions which is where you flash the newest firmware for the printer and MMU. Flashing the printer was fine, but when I try to enable the MMU in the printer settings it gives the following error message: "Can't enable the MMU: enable the printers filament sensor first.".
I have two problems with that. First, the filament sensor was already enabled. Second, the filament sensor is removed from the nextruder as part of the upgrade for the MMU. If I turn the filament sensor off and then back on in settings it asks me to calibrate it, which then fails because it is absent. None of these things allow me to turn on the MMU. When I contacted Prusa they instructed me to do step 15 of the instructions, but I can't even get past step 10. Anyone run into this problem?
Publié : 05/09/2024 9:18 pm
1 personnes ont aimé
Ryan
 Ryan
(@ryan-14)
Membre
RE: Can't flash the mmu3
And I think I solved my problem. I did what they asked me. I went to step 15 and redid the calibration for the filament sensor. The first time I tried that, it failed. This time it worked. I really do think the instructions for step 10 should warn people what to do if you get that error message. It's really counter intuitive to have to skip ahead to step 15, so that you can complete step 10.
Publié : 05/09/2024 9:27 pm
2 personnes ont aimé
BigManMakes
(@bigmanmakes)
Membre
Thank you for taking the time to post the resolution. I suffered from exactly the same confusion. I agree about making a note about sensor calibration first.
Publié : 19/09/2024 8:56 pm
Noa Simunovic
(@noa-simunovic)
Membre
I have the same problem and I tried your solution but It didn't help.
I turned on/off filament sensor and also nothing.
Do you maybe have some other solution?
Thank you, Noa
Publié : 03/01/2025 7:51 pm
iftibashir
(@iftibashir)
I had the exact same - you need to calibrate the extruder filament sensor before it will enable the MMU3 - the directions in the official guide have it the other way round. Maybe it changed with a newer firmware update....
Publié : 06/01/2025 10:46 am
Anton Holmgren
(@anton-holmgren)
Membre
I had this exact problem and managed to resolve it!I noticed that when the filament being inserted the screen flashes quickly showing that it's been detected...then back to "insert filament"...and then back to the filament detected screen.
With a finger ready on the button I pressed continue when the filament detected screen flashed the first time. This allowed the calibration to pass. I could then enable the MMU.
Posted by: @ryan-14
Publié : 28/08/2025 11:43 pm
pigtail
(@pigtail)
Membre
Thanks for the video. It reminds me I somehow changed the hardware from MK4S to MK4 and disabled MMU on the other day for troubleshoot and totally forgot about it. I turned to order failed parts and leave the printer there for a couple of months.
Then I saw "Can't enable MMU" warning and wondered why, because "8 Filament sensor calibration" was already checked. Anyway I redo the sensor calibration, the warning is gone and I can enable MMU again.
Publié : 24/11/2025 4:19 pm
kglasnapp
(@kglasnapp)
Membre
No lights on MMU when power up
I was able to successfully build the MMU3 unit I got for the Holidays. When I powered up the printer the lights on MMU3 didn't light up. I double checked the cables and everything seems correct. I also tried to update the firmware but I only got errors when I tried to update the firmware. The errors I get are Failed to update Firmware .... (bootloader) device was not found.
Any ideas as to what might be wrong. I tried with a number of USB cables and PC's with no luck.
Publié : 01/01/2026 9:12 pm
is the MMU enabled in the printer firmware?
was it the MMU3 you were trying to Flash?
If so, did you  try resetting the MMU with the Button next to the micro USB Socket while using prusa slicer to try and identify the Port that the USB was connected to on your computer?
Publié : 01/01/2026 10:11 pm
