Can not fit the 5th cassette in the buffer
Tellblom
(@tellblom)
Miembro
Upgraded mu MMU2S to MMU3S and I have a problem with the Buffer.
It seems like the hole for the cassettes are about 1mm to small and if I put four in I can not fit the fifth.
I was one of the first MMU2 users and I wonder if my sides are thicker.
Well I have redone the STL's to be a 1 mm wider and are reprinting now
Respondido : 07/02/2024 7:13 pm
Robin_13
(@robin_13)
RE: Can not fit the 5th cassette in the buffer
I am not using the MMU3 buffer but this is just a holder issue, then scale the holder a few percentage points larger to fit as you said you are printing.  You will figure it out.
Respondido : 17/04/2024 1:38 am
ad.lamy
(@ad-lamy)
Weird your width problem, but the latest version of the buffer differs a lot, the pulley cassettes are different and they are positioned more outwards, see photo.
MK4/MMU3 - VORON 2.4 350 Stealthburner
Respondido : 07/05/2024 9:53 am
Tellblom
(@tellblom)
Miembro
I have onw of the first MMU2 and it seems like my black plates are thicker than in newer versions. I made a 74mm wide version so I can fit the plates.
Respondido : 07/05/2024 9:57 am
ad.lamy
(@ad-lamy)
Mine also was one of the first for MMU2, but I never used it until today, I did not have any problems during printing and assembly.
My plates thickness is 1,5mm.
Respondido : 07/05/2024 10:35 am
