Replaced my nozzle and filament won't load
AMir
 AMir
(@amir)
Hi
I recently replaced my nozzle with a 0.25 mm nozzle to get more detail on some finer prints. I have Mk3s with MMU2S upgrade.
Now, when loading filament from MMU2S to the extruder, it will send filament down the tube to the extruder, then pull it back. This goes on a few times, and then stops. Sometimes I get an error, and sometimes the extruder thinks there's filament there and starts a phantom print. I think I have everything rotated back into place properly. Any ideas where I should start? I don't hear anything strange. Could it be banging against the heatbreak or something?
Thanks for your help!
Publié : 15/12/2020 11:57 am
Membre
RE: Replaced my nozzle and filament won't load
Check to see that the nozzle is drilled out.  There should be a hole through it.
Publié : 15/12/2020 11:58 am
Erik
 Erik
(@erik-3)
Sensor Info
Go into the sensor menu and manually load a piece of filament down through the chimney and into the hot nozzle. If the PINDA sensor ever flashes to 0 once the filament is in the chimney it will assume that a load error has occurred and try again. You need to adjust the chimney so that sensor stays 1 once the filament is inserted.
Publié : 26/10/2021 7:17 pm
