One way L bracket
michael.r52
(@michael-r52)
One way L bracket
While waiting for the MMU2S made this upgrade to the existing L bracket. It has almost no friction in the pull direction and much quicker stop in the push direction. A switch allows pullout.
The major features are:
1. Uses a US dime for the clutch. Metal teeth are grippy and weight helps response. Coin is added after printing.
2. Optimized ramp angle for grip. A slight concave bulge on bottom makes even bent fiber lockup quick.
3. Switch enables quick release for unloading.
The straight fiber path reduces friction.
Will be making a non-L version for filament case mounting below the printer.
Opublikowany : 08/03/2019 7:49 pm
Jovack
(@jovack)
Re: One way L bracket
This is a great idea. Can you share the files? Any chance you have this in F360?
Thank you!
--Rod
Opublikowany : 08/03/2019 8:29 pm
michael.r52
(@michael-r52)
--Rod
Did this in Alibre Design. I can provide that, STL, .step or the Slic3r .3mf
here is a zip file with the Slic3r file and step:
https://drive.google.com/file/d/1CNY4V3_w7PolUCPjmXeayrbo_EEraBie/view?usp=sharing
here is a step assembly:
https://drive.google.com/file/d/1Yn_ZfQSZkAR2K4usiR9i299zJDoBLC65/view?usp=sharing
Opublikowany : 08/03/2019 8:52 pm
