Octoprint Cancelled Prints
Flack
(@flack)
Does anybody have or know of a script that will unload the filament from the MMU2 when I cancel my print from Octoprints gui, at the moment if I cancel a print it just leaves the filament in the extruder and this causes me a lot of hassle trying to get it out. 😕
Opublikowany : 22/12/2018 4:37 pm
Colin
(@colin-4)
Re: Octoprint Cancelled Prints
From another user (Peter?) Works well.
G1 E-1 F7200
G91
G1 Z5 F1200
G90
M220 S100 ; Set override speed to 100%
G1 X0 Y200 F2400
G1 E5 F150
G1 E-15 F5600 ; Initial retract to get filament out without stringing
G1 E-10 F1000 ; retract filament in PTFE tube ( stages)
G1 E-10 F240
G1 E-10 F100
G1 E-10 F40
G1 E-10 F2000
G1 E-30 F2000 ; Remove filament to above drive pulley
M702 C ; Unload filament
G4 S1 ; pause 1 second
M107 ; turn off fan
M104 S0 ; turn off temperature
M140 S0 ; turn off heatbed
M84 ; disable motors
Opublikowany : 23/12/2018 4:04 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
From another user Works well.
Thanks
So pleased to hear that it works 😉
Peter
Opublikowany : 23/12/2018 4:49 pm
Colin
(@colin-4)
Thanks for posting it! :mrgreen:
Opublikowany : 23/12/2018 5:20 pm
Flack
(@flack)
Hi Peter is there anyway to select what filament to print from when using single mode on the MMU, Once the g-code is sent through Octoprint you have to go to the printer and select the filament to load, my printer is in my garage, so a nice tweak or hack would be nice to be able to select it from inside Octoprint.
Update I have just seen one of your posts and I think that answers my question, I have edited my g-code in Ocyoprint to tell it what location to use for my filament.
Opublikowany : 25/12/2018 4:28 pm
