Can I control MMU2S with arduino uno?
nowadays I'm studying MMU2S control. I succesfuly connect UART between MMU2S with arduino.
but I failed power MMU2S's motron on. so there's my question.
- is it possible to control MMU2S with arduino uno?
- if so, how to wire MMU2S, 24V SMPS and arduino uno?
RE: Can I control MMU2S with arduino uno?
Sure it is. You can find the schematics here: https://github.com/prusa3d/MM-control-2.0/blob/master/rev.03/MM-control.pdf
I would suggest to use 24V power supply and two DC/DC converters for 9V and 5V. Or only one DC/DC converter for 5V and use 5V pin on the arduino. But this is usually not advised.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
@nikolai-r
thanks so much~ DC/DC converter is good point to me. I made it working. 😆 😆
Hi @gouache95,
have you successfully managed to control the MMU2S using an Arduino?
Because i got a different Printer but want to use the MMU2S only to switch manually the Filament.
or is it maybe possible to use it manually without an arduino?!?
Thanks to evorbody
orichienal
Hi there i want to make my own mmu with arduino uno could you please tell me how you got code onto uno and how you wired up thank you
