[Fermé] Successful MMU2 prints
Page 5 / 6
JuanCholo
(@juancholo)
Re: Successful MMU2 prints
Speaking of solubles,
any chance of a link to that soluble test ball in a cage?
“One does not simply use a picture as signature on Prusa forums”
Publié : 14/12/2018 2:48 am
nuroo
(@nuroo)
https://www.thingiverse.com/make:576601
Prusa MK3 preassembled (R2/B6) > (R3/B/7)
Prusa MK2.5 kit > MK3 > MK3+MMU2 (R3/B/7) 😀
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6
CR10s4
Delta 3ku
Publié : 14/12/2018 5:50 am
JuanCholo
(@juancholo)
moderate success?
So this was created on a MMU2 (not pallete) but i used the Mosaic files.
the gears turn after it soaked in water for about 12 hours and i had to manually use a knife to get into all the areas where the soluble would not desolve on its own.
the Soluble lifted and caused some issues. there is still some contamination of the BVOH into PLA
i had to create a complex Slic3r setup to make it work.
the pallete files give you a soluble shape in the model but you cannot use it with slic3r as it will screw up the top and bottom layers between the PLA and BOVH areas.
i had to add a bunch of rules to the settings on each piece of the model.
the gears did not form 100% due to the soluable lifting and again there is still a weak spot in the PLA from the BOVH interface.
changes: i increased the Purging another 20mm for load and unload on the BVOH.
changes to lower speed again on supports increase BVOH temps to 210.
so it isn't 100% where i would of liked this to come out but it does work.
Publié : 15/12/2018 5:28 pm
Flaviu
(@flaviu)
This model is fascinating 😀
Publié : 16/12/2018 3:13 pm
JuanCholo
(@juancholo)
got mine done
Publié : 16/12/2018 7:12 pm
Printschnitzel.at
(@printschnitzel-at)
Grispy Belt (One Print Zero Assembly)
Publié : 17/12/2018 9:46 am
nuroo
(@nuroo)
Outstanding trapped ball. What was your experiences with pva? Any tips to share?
Taz6
CR10s4
Delta 3ku
Publié : 18/12/2018 12:37 am
kjgouldstone
(@kjgouldstone)
Welcome Lion
Publié : 23/12/2018 7:03 am
kjgouldstone
(@kjgouldstone)
Penguin
Publié : 23/12/2018 7:04 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Schrodinky Wizard money box
https://cults3d.com/en/3d-model/art/schrodinky-british-shorthair-cat-in-a-box-3d-printable-multi-part-model-multi-extrusion-package
3 separate print jobs, total 66 hours
Fillamentum: Red Purple, Noble Blue
Prusament: Azure Blue, Ms Pink, Silver, Galaxy Black
Prastika Trcek: White
Peter
Publié : 26/12/2018 7:47 pm
Nikolai
(@nikolai)
Re: Schrodinky Wizard money box
I see a huge MMU2 issue. The printer made pink eyes instead of Green-Black. 😆
Very nice print btw!
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Publié : 26/12/2018 8:10 pm
Nikolai
(@nikolai)
Look, who was smiling at me today:
  • Polyalchemy PLA 205C
  • Makergeeks PLA 220C
  • ~400 tool changes
  • ~18 hours print time
  • No issues
  • Often linked posts:
    Real Multi Material
    Publié : 31/12/2018 11:05 pm
    nuroo
    (@nuroo)
    Peter
    Holly molly - This guy is always moving the goal post, I have no choice but to kneel b4 you Master PJR ...... You are the undisputed world heavy weight champion, a The true Jedi Master of MMU
    Taz6
    CR10s4
    Delta 3ku
    Publié : 01/01/2019 6:32 am
    PJR
     PJR
    (@pjr)
    Thank you, kind sir. 😀
    Moving on now to test a new extruder/sensor setup 😉
    Peter
    Publié : 01/01/2019 11:22 am
    richard.l
    (@richard-l)
    Membre Moderator
    Received my MMU1->MMU2 upgrade kit last week. Spent Saturday converting my MK2S/MMU1 to an MK3/MMU2. Started my first print Sunday morning and except for a slight under extrusion it was a huge success...
    I then started my next, a 2 color sheep at 50% size. I could have increased my purge from 210 to 220 to completely eliminate the black bleed through but it is hardly notieable.
    Publié : 07/01/2019 4:13 pm
    PJR
     PJR
    (@pjr)
    Yet another "Schrodinky" cat money box (by Loubie), this time with a shiny "silk" PLA cat.
    Peter
    Publié : 08/02/2019 10:22 am
    toaf
     toaf
    (@toaf)
    that the silk bronze? the silk copper looks kick ass
    Publié : 08/02/2019 10:40 am
    PJR
     PJR
    (@pjr)
    Yes, the bronze. But the whole thing is covered with Moire pattern 🙁
    Peter
    Publié : 08/02/2019 9:23 pm
    toaf
     toaf
    (@toaf)
    that bronze stuff is neat. by mistake I ordered 2 rolls. gave me a reason to use it allot. but the copper is very very cool. even the start of the purge block looks cool
    Publié : 08/02/2019 10:04 pm
    PJR
     PJR
    (@pjr)
    I could not find the correct settings to make it work with multiple filaments though, and I also noticed that it leaves a "glue-stick-like" deposit on the bed, presumably from the "shiny" additives. It also smelt different while printing, so it worries me just how safe to use it is. I also wonder what that deposit is doing to the inside the nozzle.
    Peter
    Publié : 09/02/2019 11:20 am
    Page 5 / 6
