[Chiuso] Successful MMU2 prints
Pagina 3 / 6
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Successful MMU2 prints
Most impressive Peter. 2 day plus, 5 colors. Has to be other a 1000 filament changes?
I thought kisslicer only did 4 colors?
About 1,400 tool changes. Testing KISS pre-release with 16 "extruders".
Peter
Postato : 01/12/2018 8:04 pm
JuanCholo
(@juancholo)
phew awesome.
“One does not simply use a picture as signature on Prusa forums”
Postato : 01/12/2018 9:03 pm
toaf
 toaf
(@toaf)
im about 1300 tool. changes into a 4000 (ish) tool change print. just noticed I will run out of red.... o well. test of changing filament mid print I guess
Postato : 01/12/2018 9:42 pm
Jbravo88
(@jbravo88)
My first real MMU Print. ( 5hrs )
and my second one took 20 hrs it completed with one layer missing I was asleep and taking my chances. I'll link the Octoprint vid from my FB.
Postato : 02/12/2018 8:44 pm
nuroo
(@nuroo)
@rui.v
Those look great to me. The one layer skip doesn't look to bad, unless you have ocd. My clownfish came out like that and I felt I had to do it again and win, do the model justice.
How long did it take before you started to get success with mmu2?
Prusa MK3 preassembled (R2/B6) > (R3/B/7)
Prusa MK2.5 kit > MK3 > MK3+MMU2 (R3/B/7) 😀
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6
CR10s4
Delta 3ku
Postato : 02/12/2018 10:45 pm
nuroo
(@nuroo)
Only 802 tool changes, 27hours @pjr
The 93% failure was a logic error with Robert's firmware. The small failures were back with stock firmware and I forget stock firmware must calibrate Bowden length. Successful print was lastest stock firmware, Bowden length caliibrated.
Taz6
CR10s4
Delta 3ku
Postato : 02/12/2018 11:35 pm
JuanCholo
(@juancholo)
awesome i can't bring myself to run these torture tests any more since it goes through filament and time. i ran one last weekend and my cousin grabbed it off the bed before i had a good look at it LOL!.
its his skunk now and he loves it.
Postato : 03/12/2018 1:14 am
PJR
 PJR
(@pjr)
Peter
Postato : 03/12/2018 10:19 am
Jbravo88
(@jbravo88)
@rui.v
the snail is a keeper,
after 2 months give or take a week ( early October). I'm super happy that it's working, and the people on the fourms help a lot ( I can't say how much thank you's it would take. Now I can focus on tweaking the settings since the prints I have increased one extra cooling move and its helping with the crunch sound at the extrusion.
Postato : 03/12/2018 12:25 pm
maxx78
(@maxx78)
Adalinda
3 colors, 28 h 18min
I had one unload error where the Filament didn't clear the Finda. But i could fix it by pressing the right buttons on the MMU
And some racing frogs and a snake:
There is some color bleed as i didn't change the purge settings
Used Filaments (PLA):
- Prusament:
- Galaxy black
- Lipstick red
- Silver
- Prusa Filament:
- Rapunzel silver
-Das Filament:
- Gold
- Gray
- Blue
- Orange
- Black
And some clear PLA.
The white one is something Hobbyking sold a few years back and was laying in my basement.
the only Mod i did was my version of this :
https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f53/mmu2-another-solution-for-layer-skipping-due-to-fi-t25334.html#p115345
the printer runs the 3.4.1 firmware and the MMU the -126
All Filaments run the Prusament settings, except with a change to the load speed to 19mm/s.
The white needed a little bit more ramming (18mm3)
I tried to print frog Nr 8 with PETG and totally failed due to stringing.
Postato : 04/12/2018 10:49 am
toaf
 toaf
(@toaf)
nice, im still 20 hours away from my spiral of doom.
tool change 3220 of like 3905.
Postato : 04/12/2018 10:54 am
maxx78
(@maxx78)
where can you see the number of Tool changes ?
Postato : 04/12/2018 11:00 am
toaf
 toaf
(@toaf)
it shows in slicer after it makes the Gcode. I didn't even know that until I seen someones picture with it.. I was just doing math
Postato : 04/12/2018 11:01 am
maxx78
(@maxx78)
Thanks !
Postato : 04/12/2018 11:04 am
Ojrik
(@ojrik)
Aztec Chief
Postato : 05/12/2018 10:56 pm
Ojrik
(@ojrik)
Nefertiti
Postato : 05/12/2018 11:04 pm
Martin_au
(@martin_au)
Here's a couple of my early attempts. The sheep is all ABS. The coin is ABS (grey), PET (yellow).
Postato : 07/12/2018 5:42 am
JuanCholo
(@juancholo)
first print after some big changes to my MMU2/MK3
5 color nom-nom and candy. 10 hour print, no skips or jams.
Postato : 07/12/2018 1:56 pm
nuroo
(@nuroo)
Looking good Daniel. I dont like peppermints but I want to eat that candy.
Taz6
CR10s4
Delta 3ku
Postato : 07/12/2018 4:19 pm
nuroo
(@nuroo)
Taz6
CR10s4
Delta 3ku
Postato : 08/12/2018 7:41 pm
Pagina 3 / 6
