Re: Successful MMU2 prints
Most impressive Peter. 2 day plus, 5 colors. Has to be other a 1000 filament changes?
I thought kisslicer only did 4 colors?
About 1,400 tool changes. Testing KISS pre-release with 16 "extruders".
Peter
phew awesome.
âOne does not simply use a picture as signature on Prusa forumsâ
im about 1300 tool. changes into a 4000 (ish) tool change print. just noticed I will run out of red.... o well. test of changing filament mid print I guess
@rui.v
Those look great to me. The one layer skip doesn't look to bad, unless you have ocd. My clownfish came out like that and I felt I had to do it again and win, do the model justice.
How long did it take before you started to get success with mmu2?
Prusa MK3 preassembled (R2/B6) > (R3/B/7)
Prusa MK2.5 kit > MK3 > MK3+MMU2 (R3/B/7) 😀
Prusa SL1 3D printer + Curing and Washing Machine (day1 order)
Taz6
CR10s4
Delta 3ku
Only 802 tool changes, 27hours @pjr
The 93% failure was a logic error with Robert's firmware. The small failures were back with stock firmware and I forget stock firmware must calibrate Bowden length. Successful print was lastest stock firmware, Bowden length caliibrated.
Taz6
CR10s4
Delta 3ku
awesome i can't bring myself to run these torture tests any more since it goes through filament and time. i ran one last weekend and my cousin grabbed it off the bed before i had a good look at it LOL!.
its his skunk now and he loves it.
Peter
@rui.v
the snail is a keeper,
after 2 months give or take a week ( early October). I'm super happy that it's working, and the people on the fourms help a lot ( I can't say how much thank you's it would take. Now I can focus on tweaking the settings since the prints I have increased one extra cooling move and its helping with the crunch sound at the extrusion.
Adalinda
3 colors, 28 h 18min
I had one unload error where the Filament didn't clear the Finda. But i could fix it by pressing the right buttons on the MMU
And some racing frogs and a snake:
There is some color bleed as i didn't change the purge settings
Used Filaments (PLA):
- Prusament:
- Galaxy black
- Lipstick red
- Silver
- Prusa Filament:
- Rapunzel silver
-Das Filament:
- Gold
- Gray
- Blue
- Orange
- Black
And some clear PLA.
The white one is something Hobbyking sold a few years back and was laying in my basement.
the only Mod i did was my version of this :
the printer runs the 3.4.1 firmware and the MMU the -126
All Filaments run the Prusament settings, except with a change to the load speed to 19mm/s.
The white needed a little bit more ramming (18mm3)
I tried to print frog Nr 8 with PETG and totally failed due to stringing.
nice, im still 20 hours away from my spiral of doom.
tool change 3220 of like 3905.
where can you see the number of Tool changes ?
it shows in slicer after it makes the Gcode. I didn't even know that until I seen someones picture with it.. I was just doing math
Thanks !
Aztec Chief
Nefertiti
Looking good Daniel. I dont like peppermints but I want to eat that candy.
Taz6
CR10s4
Delta 3ku
