Wipe to infill problem
osunick
(@osunick)
I sliced a 10mm cube with a few extruder changes and selected 'wipe to infill' for the main node in the STL. I disabled the wipe tower and this is what happens- the print progresses fine until the first extruder change. Once this happens, the filament changes properly, IR sensor reads properly, but the filament doesn't extrude. If I look at the motor shaft for the extruder it doesn't seem to move. It will continue to switch filaments and "print" in air without extruding without any errors.
Here is the gcode
It switches between extruder 4 and 5, both with prusament PLA. Any ideas? This feels like a gcode problem but I'm not sure what I'm doing wrong. This happens with any print I try to enable 'wipe to infill' on, I just made a simple test so I could debug.
Thanks!
Veröffentlicht : 28/06/2020 5:15 pm
