wipe object and wipe to object
Ok, finally got the MM2 running. What a pain the arse. First the Pi was not even loaded with any hex, then the filament was not reaching the extruder so i had to manually set the lenght. Now it is all good. I went into slicer following the handbook, i click on the object in 3d view but i get no option to use infil as wipe or create anothe object with the wipe. Not sure if I am doing something wrong or just not seeing it. Can anyone help?
Opublikowany : 29/09/2018 6:14 am
Re: wipe object and wipe to object
try double clicking there
Opublikowany : 29/09/2018 8:52 am
