unable to dissolve PVA in water
ammedia3d
(@ammedia3d)
Hello, im using Prusa Mk3s with MMU2s installed. I try to print a part (PLA) using soluble support interface (PVA), but when i put the model inside warm water, after 3 hour PVA will be gelatinous and very difficult to remove from the model. Purging volumes is: 140 load / 100 unload for tool#5 where PVA is loaded ... can someone have experience with soluble supports ? thanks in advance
This topic was modified 6 years temu by ammedia3d
Opublikowany : 27/02/2020 9:17 pm
Zoltan
(@zoltan-d-2)
Member Moderator
RE: unable to dissolve PVA in water
Moving your post to english forum, you could get more answers.
Opublikowany : 29/02/2020 10:50 am
