suports missing in Slic3r 1.41.0+
I am trying to print a test object that needs support for a large central area (“obj” pic below).
In Slic3r (1.41.0) I selected the “Support on build plate only” option.
However, the preview shoes support material only at the ends. 90% of the center is unsupported. (“support" pic below).
I looked through the Print Settings and couldn’t see any way to make the support cover the whole area.
I went ahead and printed the object and the suports were missing as indicated in the pic.
How do I get the whole area supported?
Opublikowany : 29/09/2018 9:45 pm
Re: suports missing in Slic3r 1.41.0+
You have the "Don't support bridges" feature enabled, therefore the bridges are not supported.
Opublikowany : 03/10/2018 9:54 am
