Strange problem loading wood fillament
Nomad
(@nomad)
Hello fellow printers,
I have a good working MK3S and MMU2s for almost a year now.
And it is still working prefect in multicolor and single color when using PLA and PETG.
But... when i want to use wood fillament (colorfab) it will load/unload/load/unload etc.
This only happens with the wood fillament. It dous not matter if i use the colorfab wood profile or prusament PLA profile.
I hope someone here have a idea of why this is happening and how i can solve this becouse i realy wanted to print a present in the wood fillament.
Respondido : 18/05/2020 6:17 pm
Agkirk
(@agkirk)
RE: Strange problem loading wood fillament
What are the sensors showing in the Support page?
Respondido : 18/05/2020 9:36 pm
DarcShadow
(@darcshadow)
Try disabling the filament sensors. The sensors just don't like some filaments.
Respondido : 18/05/2020 10:18 pm
Nomad
(@nomad)
Thank you @1agkirk2 and @darcshadow for your inputs, it got me thinking 🙂
Ok, so i am printing the wood fillament right now.
To get it to work i had to disconnect the MMUS2 and sliced the model for a normal MK3s.
I unpluged the tube from the extruder to insert the wood fillament directley with the load fillament function.
Then started the print.
I did also some testing with the fillemnet sensors, and everytime i manualy instert a peice of fillement it would be detected and when i removed it, it also sees it corectly. So why the MMU2S and the MK3S do not work together with this fillemant is for me a big puzzle.
It is until now the only fillament that i have this issue with.
I also have the bronsfil so that will be the next try...
Respondido : 19/05/2020 7:23 am
Dps
 Dps
(@dps)
Same issue using MK3s+ MMU2s.  Interesting note from me is that the filament moves freely and easily to the mmu.  When it tries to load to the hot end, the MMU grinds a hollow into the filament indicating that it is bound somewhere. When I disengage the mmu (undoing the screws and lifting the bearings) the filament moves freely indicating it is not bound......  I somehow feel that the Curse of Oak Island is in play here.
I am also going to reslice and take the mmu out.
Respondido : 05/02/2021 3:31 pm
