PVA & Prusa Slicer (Wipe Tower supports non-soluble supports)
jmone
(@jmone)
Newbie Q on PVA.  With the new Prusa Slicer how do you print PVA Supports?  I tried using the MMU2s profile and assigning the supports to Extruder 2 but I then get a msg saying "The wipe tower currently supports the non-soluble supports only...." and it either turns off the Wipe Tower or sets the extruder to 0 for supports.
Thanks
Nathan
Veröffentlicht : 25/05/2019 10:11 am
markus.i2
(@markus-i2)
RE: PVA & Prusa Slicer (Wipe Tower supports non-soluble supports)
IIRC (at least I think that worked for me one or two SW updates ago...) you have to assign the soluble material to Extruder #5.
Veröffentlicht : 05/06/2019 4:27 pm
m2tts
(@m2tts)
I also am confused by why the wipe tower goes away if you want to specifically assign one material to be the support. For instance, I have two materials I'm printing (one material is created as a part to form a support interface) and I want the the material I'm using for the main part to also be used as the support under the second material, but I'm not allowed to set that extruder to also be the support material without disabling the wipe tower. Why not? I'm using two materials; a wipe tower is a necessity, yet it wants to use extruder 0. When it does that it is then using both materials as support materials and I specifically don't want to do that as one of the materials is expensive and I don't want to waste it.
Veröffentlicht : 27/06/2019 3:13 pm
Joppo
(@joppo)
primero tienes que poner en configuración de impresión un perfil para material  soluble , despues ya pues  poner la torre de limpieza y dos filamentos solubles uno para soporte intermedio (cualquier filamento normal ) y otro el material soluble para los extremos , de esta forma se consume menos filamento soluble . si lo haces bien veras que la forma de la torre de limpieza a cambiado de forma y tiene una parte escalonada .
pero los tiempos de impresión son inmensos ,
estoy buscando la forma de que se pueda cambiar el filamento sin necesidad de usar la torre de limpieza y que limpie por ejemplo con el material de relleno , hay una opción que te permite  imprimir primero el relleno antes que los perímetros, lo que ocurre es que que si tiene poco relleno en piezas pequeñas se queda alguna capa sin imprimir , si alguien sabe como mejorar esto lo agradecería
también e visto en tergiverse una impresora que no usaba torre sino una especie de pieza que al pasar el extrusor  varias veces por ella lo limpiaba y dejaba el filamento preparado
Veröffentlicht : 13/09/2019 12:05 am
