Problems with PRUSA posted G-Code "Original Prusa i3 MMMU2 MKMU2S upgrade:"
JohnnyT
(@johnnyt)
I having trouble printing Posted G-Code "Original Prusa i3 MMMU2 MKMU2S upgrade:" What printer were these built for? Keeps rebooting my PRUSA i3 MK3 +MMU2 using firmware Firmware 3.6.0 (1.0.5)
Thanks,
JT
Veröffentlicht : 05/03/2019 11:34 pm
JohnnyT
(@johnnyt)
Re: Problems with PRUSA posted G-Code "Original Prusa i3 MMMU2 MKMU2S upgrade:"
I should clarify. I've tried printing the MMU2S parts only.. Cheers
Veröffentlicht : 05/03/2019 11:47 pm
joseph.w8
(@joseph-w8)
I ran into the same problem. I was able to get it to print on my MK3+MMU2 by loading the filament to nozzle.
Veröffentlicht : 06/03/2019 2:13 am
 Anonym
I have the same problem.
I have tried to update my mk3/mmu2 to the last 2 firmware releases 3.5.2/1.04 and 3.6/1.05 on both occasions the printer fails with the same symptoms and I have had to revert to the previous Firmware 3.5.1/1.03 and the printer works fine. With the update everything calibrates fine and I start a print , during the first couple of layers the printer just resets and stops, it is as though the printer has just been turned on. I have tried several different models with the same result each time. There are no error messages.
Veröffentlicht : 10/03/2019 3:05 am
JohnnyT
(@johnnyt)
Thanks,
That did it. 😉 JT
Veröffentlicht : 13/03/2019 3:26 am
