Problems slicing a model
Lvet
 Lvet
(@lvet)
Hello,
Whenever I try to slice a specific model, the results is rather strange with a floating line on top of the purge block.
According to Prusaslicer the model is manifold.
Whenever I try to print it with the MMU2S, it's failing in exactly the same point early on in the print after approximately 3 hours.
It looks like the tower breaks in two. I am not sure if it might be a problem with my setup or a problem with the file.
(unfortunately it's a copyrighted file that I cannot post here, but I can send it by direct message if you want to have a look at it)
Este debate ha sido modificado el hace 5 years por Lvet
Respondido : 03/01/2021 6:12 pm
