Pause printer after certain layer or height
Kamil
(@kamil-3)
I would like to pause a printer after certain layer or height in order to add some part in the model. Can I do it in slic3r somehow? I know that it can be added a gcode to the slic3r but honestly I do not know how it should be done. I know that I should add something in Printer settings -> Costume gcode but where and what I do not know really. Any help would be appreciated.
Opublikowany : 12/10/2018 10:11 am
Re: Pause printer after certain layer or height
Hi Kamil.
have a look at the last post .n this thread> https://shop.prusa3d.com/forum/others-archive--f82/pause-print-in-gcode-t2034.html
Opublikowany : 12/10/2018 3:15 pm
Kamil
(@kamil-3)
Thanks for a link. I have done it just putting a command within the gcode file:
G4 S20;
M0 Click To Restart ; Pause and wait for the user
Can I automatise it without opening the output file from slice3r?
I can add it in the Custom g-code as a command before layer change for example, however it change for each layer. Can I set only one desired layer?
Opublikowany : 12/10/2018 4:09 pm
Hi Kamil,
I believe you can specify the level in custom code,
never done it myself.
Opublikowany : 12/10/2018 5:20 pm
