MMU2 - Brim Color
scorrales
(@scorrales)
MMU2 - Brim Color
I have a unique situation. I am printing a part in multiple colors. The first layer has some text in Blue and the rest of the layer is white. The first time I tried to print, the white was printed first then blue. This resulted in the lettering not being clear. I did not know how to change what was printed first. I noticed that I had White a Filament 1 and Blue as filament 2. I tried switching the colors and put blue as 1 and white as 2. I made the changes in Slic3r made new gcode. The result was perfect the text comes out very crisp.
But by the time that part is complete I am getting some distortion in the part. The part is lifting in some places. I added a brim and that is helping. But the problem is that the brim is blue and the edge of the part is white. When I try to remove the brim, alot of blue is left behind. To remove all the blue i had to cut away from the part.
Here is my question, in Slic3r PE, is there a way to choose what color the brim will be?
Postato : 04/03/2019 9:06 pm
gnat
 gnat
(@gnat)
Re: MMU2 - Brim Color
I don't have the answer to your specific question, but have you addressed all the normal issues around prints lifting?
Since learning how properly clean my PEI sheet and getting my Z better dialed in I haven't needed to add a brim to anything.
MMU tips and troubleshooting
Postato : 04/03/2019 9:52 pm
scorrales
(@scorrales)
I do not have a PEI sheet. I order my printer without.
The part is 50mm x 130mm x 3.5mm thick. It is 100% infill. I am getting a good first layer but over time it will start to lift. I increased the bed temp for 60 to 75 and than has helped.
Postato : 04/03/2019 10:00 pm
toaf
 toaf
(@toaf)
slicer/printer settings/multiple extruders maybe?
Postato : 04/03/2019 10:44 pm
scorrales
(@scorrales)
It looks like the setting is Extruders - Support material/raft/skirt extruder. I will test in the morning.
Thanks.
Postato : 05/03/2019 6:38 am
scorrales
(@scorrales)
Multiple Extruders options can change the color of the skirt, raft and support material but not the brim.
Any other ideas?
Postato : 05/03/2019 3:01 pm
richard.l
(@richard-l)
Utenti Moderator
What surface are you printing on? From Prusa it will be either flex steel with a PEI sheet adhered or flex steel with powder coat PEI.
Postato : 05/03/2019 6:06 pm
scorrales
(@scorrales)
Just the flex steel.
Postato : 05/03/2019 6:39 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
With a PEI sheet stuck to it.
Peter
Postato : 05/03/2019 9:46 pm
scorrales
(@scorrales)
No, I am not using the PEI sheet. Is it really worth it? I have one but have not gotten around to putting it on.
Postato : 06/03/2019 10:23 pm
richard.l
(@richard-l)
Utenti Moderator
YES!
Postato : 07/03/2019 4:48 pm
