MMU2 and ColorFabb nGen settings
stephen.o9
(@stephen-o9)
Are there anyone who care to share successfull Advanced settings and ramming settings for ColorFabb’s nGen filament.
I seem to get very stringy tips with the PET settings and this is blocking my FINDA and disrupting the unloading process
Thanks in advance. 😉
Best Regards Stephen Odgaard
Copenhagen DK
Postato : 09/11/2018 9:01 pm
Flaviu
(@flaviu)
Re: MMU2 and ColorFabb nGen settings
I tried and gave up. nGen is notorious for stringing. Colorfabbs PLA/PHA works much better. But even with that I am not at a success rate which I’d like to have.
Postato : 11/11/2018 10:59 am
andrew.h52
(@andrew-h52)
Did you manage to get the nGen filament working? I have tried the settings in the single extruder setup which is 100 deg for the bed and 240 for the extruder. With this I am getting very stringy ends resulting in MMU errors. Should I look at lowering the temp and try that or is it more to do with the loading and unloading?
Postato : 13/02/2019 11:34 pm
stephen.o9
(@stephen-o9)
I havent concluded (decided to by a bulk of PLA). 🙂
But I do find that a lower temperature helps the stringing. The problem is that I need a higher temperature 230-235 to get proper adhesion between the layers...
All good ideas are welcome.
Copenhagen DK
Postato : 14/02/2019 12:50 am
