Leaving a ball under extruder - soluble interface settings
Hello,
I'm trying to print out an object with soluble support. The object made from silver PLA, the support is from Esun PVA. Printing layers with silver is no problem, but as it changes to PVA it leaves a small PLA or PVA 'ball' under the extruder. Also I hardly print with PVA, it seems it's melting too much on 200°C however it's suggested working temp is 180-210°C. Maybe I should try another company's product?
Here is the 'ball' in the Wipe tower.
Ce sujet a été modifié il y a 7 years par Balazs Toth
Publié : 09/05/2019 2:30 pm
RE: Leaving a ball under extruder - soluble interface settings
Is this using an MMU? If so, need a moderator to slide this thread over to that forum.
Publié : 09/05/2019 8:07 pm
