How to print with PVA using a MMU2S / slicing it in PrusaSlicer
[Rozwiązany] How to print with PVA using a MMU2S / slicing it in PrusaSlicer
G-J
 G-J
(@g-j)
If I load the PVA in extruder 5 and want to print the part with PLA in extruder 4. I select the materials in the slicer (PVA as Verbatim BVOH) and  soluble profile,  slice it you don't see anything in the perview and when printing it won't print the PVA.
Tested the MMU2S with a 5 colour print and that worked fine, but printing with PVA doesn't work till yet.
Can't find anything about this topic on Youtube as well on the internet about the right instructions how to set it up the right way in the slicer.
Can you help me with the right setup so it will work.
Opublikowany : 08/10/2020 1:16 pm
