How exactly do model for MMU? The steps in Fusion just dont work.
MartinD
(@martind)
Hello I wanted to create MMU colorful models, but there is no guide which would work.
In Fusion 360 guide, there is no Save as STL anymore, so not useable, I tried also Make 3D print
(see picture, I already created several bodies, but cant imort them correctly to prusaslicer 2.0)
https://imgur.com/l34qwQu
I also tried to use Meshmixer (see the colors, so it knows there are different parts)
https://imgur.com/YCSfxLn
But separate shells create only one shell (all bodies in one) - I used the same file as in Fusion which recognized bodies, but cant export them
Do someone knows a working way to create MMU object (I do not find anything after lot of googling - and I dont want to pay for software until I know it works), and it limites the MMU usage basically to zero.
Este debate ha sido modificado el hace 7 years por MartinD
Respondido : 16/08/2019 12:17 pm
ntdesign
(@ntdesign)
RE: How exactly do model for MMU? The steps in Fusion just dont work.
There a several ways to split up models or model directly in OpenSCAD.
Respondido : 16/08/2019 12:19 pm
MartinD
(@martind)
Posted by: nils.t
OpenSCAD does not import STL or OBJ files.
Respondido : 16/08/2019 12:22 pm
ntdesign
(@ntdesign)
Yes it does.
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Importing_Geometry#import
Respondido : 16/08/2019 12:33 pm
Petour
(@petour)
I have used tutorial at this URL https://support.mosaicmfg.com/hc/en-us/articles/115002827014-Convert-Single-Color-STL-files-into-Multi-Body-Models-using-MeshMixer to convert a single color model to a MMU model.
Respondido : 16/08/2019 1:31 pm
Peter L
(@peter-l)
Posted by: martin.d17
It looks like you might be in "Mesh" mode. You need to click the "Finish Mesh" button to return to "Model" mode.
From there you can export your object as an STL.
Yes, this is something of a user interface problem--there's no good reason why "Export STL" should only be available in "Model" mode. But that's the way it is.
Respondido : 17/08/2019 5:55 pm
stephen.h14
(@stephen-h14)
New MMU user here myself. I struggled first when putting models into PrusaSlicer because I was trying to add each model. I needed to add only the first model part and pick one that would sit on the bed and then use the load option for each additional model. It worked pretty much like this tutorial (except this is for Slic3r PE):
https://manual.prusa3d.com/Guide/Gcode+preparation+for+Multi+Material+v2.0/424
There's definitely a lack of good tutorials for PrusaSlicer and MMU models or I'm using the wrong search terms.
Respondido : 19/08/2019 8:59 pm
