Help resuming failed print
Roichu
(@roichu)
Good morning everyone!
After 12h of printing, I touched the SD Card while cleaning around the printer and the print stopped (yeah, my fault).
I was wondering if anyone knows how to adapt the gcode in order to resume the print. It stopped in X125.9 Y115.6 Z130.40
If you know how to save this poor print, please, let me know! Thank you in advance! 😉
(I attached the gcode in zip format, I can share it via google drive if needed. Also, im printing on a mk3s+mmu2s)
Attachment removed
Best Answer by vintagepc:
load your STL, cut at that Z height, print upper half on sheet,and glue it on. Trying to resume on top of existing print structure is far riskier.
Publié : 11/10/2019 12:47 pm
vintagepc
(@vintagepc)
Membre
RE: Help resuming failed print
Publié : 11/10/2019 12:57 pm
1 personnes ont aimé
Petour
(@petour)
In theory, it is possible to resume the print, but there is not enough information from you.
Is the print still stuck to the print bed properly?
Does the printer still know the current print head position?
Are you able to send g-code commands to the printer (etc. through Octoprint terminal)?
Are you able to find the exact position of failure in your g-code file?
Publié : 11/10/2019 1:32 pm
