Geometry lost after slicing multi part object
guziko
(@guziko)
Hello, I've been struggling with this issue for a while now and can't figure how to solve it.
So I have prepared two parts of the multi-colour objects. Both are watertight and share the coordinates.
When loaded into Prusa Slicer they appear right but after slicing, the 'number' elements are lost. The automatic geometry repair in the Slicer doesn't help. What's the issue?
Please see the screenshots provided. Thanks in advance!
Kuba
Postato : 24/03/2022 9:20 am
RE: Geometry lost after slicing multi part object
The chances are that your letter strokes are too thin. Can you use BOLD text. With a plain typeface.
Postato : 24/03/2022 9:48 am
Thejiral
(@thejiral)
There is the option of automatically broadening too thin elements in the slicer settings. If you tick that on before slicing, are you then seeing the numbers? If so, they are too thin in the original file for your nozzle.
Postato : 24/03/2022 11:33 am
guziko
(@guziko)
@JoanTabb The letters are around .8 mm thick. The very same thickness was applied before to a different version of the model and it printed out fine:
I now made the square 'holes' deeper and the whole model thicker and it fails to slice properly...
@Thejiral Sounds cool. Where can I find this option?
Appreciate your help.
Questo post è stato modificato 4 years fa da guziko
Postato : 24/03/2022 2:05 pm
