Explanation of the difference? MMU2S spool 1 and MMU2s Spool 5, identical settings
Questa discussione è stata modificata 4 years fa 2 tempo da AndrewS
Postato : 23/01/2022 9:55 am
RE: Explanation of the difference? MMU2S spool 1 and MMU2s Spool 5, identical settings
Too much friction in filament path of spool 5 resulting in under extrusion because the extruder cannot pull the filament fast enough.
Check PTFE tube connections on the buffer (screws) and on backside of MMU2 (consider installing pass through adapter)
Postato : 28/01/2022 9:41 am
