BVOH support on very fine detail prints
So I'm trying to print some miniatures in PLA with BVOH support. I've seen a lot around about this, but I'm having one specific issue that I can't seem to figure out. I'm printing with a 0.25 nozzle, on 0.05 layer height, 65 degree bed temp, with the smooth sheet (I've read that things seem to stick easier to it?). PLA adheres without issue at all, as does the wipe tower. However, the BVOH does not want to adhere to the bed at all when it's not started right next to the PLA.
Is there a way to tell Slic3r to do a raft with the PLA? I would imagine this would help.
I'm currently just using IPA to clean the sheet. Should I be doing something else to help with adhesion?
Napsal : 10/12/2019 5:09 am
