Assigning different support materials
moritz.skowronski
(@moritz-skowronski)
I want to print several models at the same time. All of them need support material. However, I want to print one of them with soluble support and the others with regular filament. Is there a way to specify the support filament for each model?
Thanks,
Moritz
Publié : 30/01/2020 12:44 pm
gyro
 gyro
(@gyro)
RE: Assigning support materials to one dedicated extruder mmu2s
servus, I've a similar situation as Moritz mentioned.
I've a mk3s and mmu2s,  slicer 2.2. alpha and latest firmware in both.
I'd like to e.g. set filament / extruder 5 to solutable filament - PVA. But I can't force the support material to use extruder 5. it is always the same extruder used as the object/model is using. = support material is using the "object extruder" = same filament
any ideas or have a overseen a feature
regards
werner
besten Dank / kind regards
MK3S & MMU2S, Ender 3 Pro
Publié : 03/02/2020 7:01 pm
gyro
 gyro
(@gyro)
RE: Assigning different support materials
PS: I've found the "print setting - multiple extruder" but selecting the support material / interface  , I'll loose the wipe tower.
Publié : 03/02/2020 7:49 pm
