Assembling multiple STL for MMU Print
I want to print the Cheshire Cat as a MMU Print but i have no idea how to "assemble" the parts before slicing them.
I tried to do it im Solidworks, but it keeps chrashing....
I tried Meshmixer, but it is quite difficult to use and is driving me nutst.
any suggestions ?
Re: Assembling multiple STL for MMU Print
Your answer is here: https://shop.prusa3d.com/forum/others-archive--f58/successful-mmu2-prints-t25633-s30.html#p117790
Peter
Thanks for the update.
I had another try using Solidworks and it looks good.
When (if) i finish it, i will share it on Thingiverse
I didn't finish because Solidworks was overloaded.
But i found that somebody already had made the Model:
https://www.thingiverse.com/thing:3035410
Which is linked in the post I suggested you look at 🙁
Peter
Ouh...i am Sorry.
i must have overlooked it.... 😳 😮
Ouh...i am Sorry.
Not a problem 😀
I have the 4 STL from the original designer. However, it had lots of faults which I eventually managed to fix using multiple programs.
You need to split the white mesh and print the eyes with yellow filament - not sure how to do it in Slic3r.
Peter
i will probably stay with white, because i am thinking of a color scheme more in gray and blue/green like the cat from the movie.
So the stripes will be gray and a translucent blue with green infill and then i have only black and white for whiskers and eyes.
Of course, you youngsters don't remember the 1951 original 😉
Thick build and a primarily pink coat with purple stripes. Wide smile and close-set, piercing yellow eyes
Peter
Peter
Thanks for calling me a youngster ! i am feeling quite of old lately seeing the babys of my friends are driving cars now...
..maybe i get the '51 version, but i quite like the "new" cat.
Pleasure 😉
Peter
