Anybody have a working 3mf file for soluble INTERFACE?
Wes
 Wes
(@wes-4)
I have soluble material (primaselect PVA+) working fine with the default SOLUBLE FULL profile in Prusaslicer.
However, the SOLUBLE INTERFACE profile seems not to work.  First, there is what seems to be a bug where the soluble material is also mixed in the support, as I describe here:
https://github.com/prusa3d/PrusaSlicer/issues/3665
And there is also a thread going about how the patterns for support and interface don't line up correctly:
https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-how-do-i-print-this-printing-help/help-with-support-interface-is-required/
But clearly soluble interface was working in Slicer PE in 2017, according to the blog:
https://blog.prusaprinters.org/printing-soluble-interface-supports-prusa-i3-mk2-multi-material/
So I'm wondering, does anybody have a workaround to get soluble interface working?  (No soluble material in the supports; only in the interface?)  Could you share a 3mf file so I can see how you do it?
Thanks!!
Napsal : 16/02/2020 7:11 pm
Wes
 Wes
(@wes-4)
RE: Anybody have a working 3mf file for soluble INTERFACE?
To follow up:
The bug with the soluble support only affects Prusaslicer version 2.2.0-alpha4.  Discussion is here:
If you use alpha2 it is fixed.  It will also be fixed in the Beta.
Napsal : 18/02/2020 6:14 pm
