What versions of MMU2 to print
Paul Meyer
(@paul-meyer)
I received my mk3 MMU2 upgrade a week ago. The idler broke during initial filament loading (described in this post) and I have to reprint the idler.
I grabbed the stl's from here and started printing. I realize, however, that the idler I'm printing is different from the one I received with my kit. Specifically, the first layer on the kit idler is solid end to end, where the one I'm printing has breaks across the part to the left/right of the M1 label. That isn't a problem.
The problem is: what other changes might there be? How can I be sure the one I downloaded from that link is compatible with the other kit parts I received? Should I reprint the whole MMU?
It would be nice if PR actually used version numbers, included them on the print, and had documentation on what versions of what parts were compatible.
Publié : 16/09/2018 8:25 pm
