unloading filament, not able to cut off a tip
Peerke
(@peerke)
hi
i had the possibility to cut off a top off the filament after unloading.
it went back into the selector then the selector went sideways so the filament could come out, with made it possible to cut off a piece of the filament. for some reason it doen not work anymore (the filament stays in) although it is possible to reload I like this feature back since it works way better as it does without cutting of a bit.
i am not quite sure if this feature stopped after a firmware upgrade. it could be a setting but I can't find any setting wich could make this happen.
so is it firmware/software or setting related?
kind regards
Opublikowany : 18/11/2019 10:45 am
Peerke
(@peerke)
RE: unloading filament, not able to cut off a tip
no idea's?
Opublikowany : 27/11/2019 4:10 pm
