Unexpected MMU2+ behavior
BeverlyDSullivan
(@beverlydsullivan)
I've recently noticed some unusual behavior with my MMU2+. Sometimes it won't switch filaments properly or gets stuck during loading/unloading. Everything was working fine before and I haven't made any major changes to the setup.
I've rechecked the filament path and cleaned the mechanism, but the problem persists.
Is anyone else experiencing similar issues?
block blast
Opublikowany : 20/04/2025 8:26 am
RE: Unexpected MMU2+ behavior
the filament sensor tower is quite fiddly and difficult to adjust. i would print the mk3 filament sensor tower and idler door, i think the stl's are inmmu3 printables page
Opublikowany : 20/04/2025 4:19 pm
Harold Vincent
(@harold-vincent)
Make sure your printer, MMU2+, and slicer profiles are up to date with the latest Prusa firmware and software versions.
Harold VincentAre you ready to jump with Geometry Dash?
Opublikowany : 24/04/2025 7:25 am
