Slicer bad allocation error
Sam Smyly
(@sam-smyly)
Im trying to print D.V.A's mech from overwatch using soluble support on my MMU 2, but everytime i slice it in MMU2 (slicing it using the regular mk3 works fine) it comes up with bad allocation error. Ive tried full soluble, interface soluble, ive quit the program, ive uninstalled it and reinstalled it but nothing works
Opublikowany : 15/12/2018 8:36 pm
xander.j
(@xander-j)
Re: Slicer bad allocation error
Im having this same issue, also trying everything to no avail, does anyone know how to fix this? :/
Opublikowany : 11/04/2019 6:37 pm
Nikolai
(@nikolai)
Please place a ticket https://github.com/prusa3d/Slic3r/issues and provide as much information as possible there. The devs need to look at it.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 11/04/2019 6:40 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
You may be low on RAM. How much RAM is there in your system?
Also please make sure you are running the Win64 build on Windows, not the Win32 build.
Opublikowany : 12/04/2019 1:25 pm
Snipermax
(@snipermax)
RE: Slicer bad allocation error
I have the same error on my computer, I checked the RAM, still has a lot, not in use. I have 16G in total, only 7G been used.  don't know why this happens. any clue?
MK3S+MMU2S
Opublikowany : 01/09/2019 5:55 am
Dave Avery
(@dave-avery)
grab a copy of the beta3 prusaslicer 2.1.0 from https://github.com/prusa3d/PrusaSlicer/releases
and see if the problem has been fixed
Opublikowany : 01/09/2019 9:26 am
