Slic3r Re-arranging Multi-material prints for the MMU, what am I doing wrong?
Clem
 Clem
(@clem-2)
So I have just got a MMU and so far so good. It prints the example models fine and I figured it was time to start slicing my own.
I found this on thingiverse as a good starter model
https://www.thingiverse.com/thing:2649487
It contains a set of STLs that fit together, they clearly are not all modelled at the origin. However, when I import them to Slic3r they are automatically moved to the centre of the bed and dropped down to sit on the bed. I cannot find a setting to stop this (I found one that stops auto-arranging but that is already off). I even found a setting that allows the stls to be combined within slic3r which places them in the appropriate places (but merges them into one stl as far as I can tell) so I know the location info is present!
What am I doing wrong?
thanks
Phil
Publié : 14/05/2019 10:34 am
Clem
 Clem
(@clem-2)
RE: Slic3r Re-arranging Multi-material prints for the MMU, what am I doing wrong?
I think I've gotten around the problem by adding 1 stl, double clicking it and then clicking "load part" or similar. This allows all parts to be added and not be one thing. Within this sub window I can assign each stl to an extruder as I wanted.
I havent set the print going yet but it looks like it should work. This is not at all an obvious solution.
Publié : 14/05/2019 1:28 pm
Hi Philip,
Select all parts  at one time and slic3r will alert that multiple parts are being loaded,
select yes
and you get this
Publié : 14/05/2019 8:25 pm
