Selftest Error ! Pleae check : Axis lenght Axis x
Hi all,
I have a problem: Selftest failed ....
Before that I got the Error X lenth ... and xyz calibration error.
The printer was o.k. before - until yesturday. It started with a failed print - suddenly on the rigt side the print was incorrect. I stopped it and then I tried e.g. to calibrate it. But then other error occured: xyz calibration failed. Bed calibration was not found.
And know I didn't even come to that point, because when I started the printer today, it stopped the elftest with an Error.
Has anyone an idea what I can do?
Is it possible that the x linear gearing causes the problems?
Best Regards Günter
Opublikowany : 04/05/2020 12:37 pm
Topic starter
answered:
RE: Selftest Error ! Pleae check : Axis lenght Axis x
Opublikowany : 04/05/2020 12:50 pm
