[Solved] Selector won't move
christian
(@christian-4)
Selector won't move
Hi Everyone,
I've just upgraded my MK3+ to MMU2S, I have a problem with the selector.
It refuses to move, trying upload filament 1 it don't move to the position. Using right button og left button does not work. Powed off it's sliding just fine. Powed on it's locked. Any tips?
/Christian
Napsal : 10/06/2021 7:03 pm
christian
(@christian-4)
RE: Selector won't move
Update: Selector and pulley are both inactive. Only the Ilder works. All the connections are correct. Firmware updated to last version. Any way to test what could be wrong?
Napsal : 10/06/2021 8:19 pm
christian
(@christian-4)
Problem solved. The FINDA sensor was blocking
Napsal : 11/06/2021 4:43 am
Baklin
(@baklin)
Good to see you found your problem.
When trouble shooting the MMU it is good to know how things work and in what order.
This video shows that very good:
It has helped me a lot.
Napsal : 11/06/2021 10:55 am
christian
(@christian-4)
Thanks! Great video!
Napsal : 11/06/2021 6:20 pm
