Purge Block Speed
During purging, even when print speeds are manually adjusted with LCD, the speeds reset to 100%. The purge block needs to be able to have a speed setting for each filament. Some filaments will not bridge at print speeds, which happens during high purge cycles, and the speed needs to slow down. If it tries to bridge at the higher speeds it destroys the block due to clumping of the filament between bridge areas.
Napsal : 03/11/2018 3:01 pm
