Pulley motor can only turn slowly. How to troubleshoot?
ajamer
(@ajamer)
I have an MMU1->MMU2 upgrade setup with the coupler needed for my pulley motor shaft.
During rapid loading and unloading the pulley motor gets stuck and does not rotate at all nor the shaft
It then does the slow moves successfully to get to the IR sensor or FINDA  just fine. Prints end up succeeding but it takes extra long to do filament swaps. Ive checked the coupler grub screws and the shaft in the bearing seems to spin just fine when I turn it by hand
My bearing with the shaft is really stuck in place and I'm afraid If I disassembly I'll break the 3D printed parts
Any  commands I can send to force rapid motor movements?
Opublikowany : 03/08/2020 3:18 am
