Problem with March 1st firmware (3.6.0)
eschlenz
(@eschlenz)
Has anyone else installed the 3.6.0 (March 1st, 2019) firmware, and experienced problems? I had to revert back to the previous version. Here is what I observed:
  • Print starts
  • Extruder / build plate begin heating
  • Extruder / build plate reach correct temperature
  • MMU2 initializes
  • Extruder gear starts running (rotating) before MMU2 even selects filament
  • Extruder gear continues running as MMU2 delivers selected filament
  • Extruder stays running, docked in the home position, spitting out a huge blob of filament
  • I've waited up to ten seconds as it does this, but at that point there's a huge messy blob being built up, so I cancel the print. It only happens with the 3.6.0 firmware. The previous version works without issue.
    Anyone else seeing this issue?
    Publié : 19/03/2019 11:25 pm
    PJR
     PJR
    (@pjr)
    Antient Member Moderator
    Re: Problem with March 1st firmware (3.6.0)
    Do you have the Mk3+MMU2 (non "S") but have installed the "S" firmware version?
    Peter
    Publié : 19/03/2019 11:29 pm
    eschlenz
    (@eschlenz)
    Peter
    No, but I think you just answered my question. I have the MK2.5 with MMU2, but I installed the MK2.5S firmware. I'm still waiting on the MK2.5S upgrade stuff. So I believe that's where my mistake was.
    Thanks for the tip! I'm going to try installing the MK2.5 (non-S) firmware now. ( doh! )
    Publié : 20/03/2019 1:01 am
    eschlenz
    (@eschlenz)
    Just following up. That was definitely my issue. These Prusa model names are starting to get confusing! 🙂
    Publié : 20/03/2019 5:35 pm
    PJR
     PJR
    (@pjr)
    +1 on that 🙁
    Peter
    Publié : 20/03/2019 5:39 pm
